Home › Forum › Ask A Member › OMC Pressure tank latch spring
  • #6707
    Doug Wilson
      Does anyone have a suggestion of where to find a spring that will work on the latch for an OMC pressure tank fuel connector.
      Connector seems to be in good shape but the spring is broken. Looks like a smaller clothes pin spring. I picked up a couple of
      tanks recently and that seems to be the only problem other than fuel line being cracked both tanks are little dirty inside but no signs of
      rust or corrosion. One of them even the paint is in good shape.
      Thanks
      Doug
      Doug
      turned off?
      #55832
        Wow, what an unusual request! Anyway, marineengine.com has 10+ of them. Part number 301829, $3.07 ea.
        #55834
        olcah
          Ebay has them too, $7.31 with free shipping.
          #55837
          Doug Wilson
            never seen one of those springs break either, odd because the tank is in great shape otherwise. Could not pass up two
            clean tanks for what I spent.
            Doug
            turned off?
            #55849
              Several tanks used the same parts – why re-invent the wheel. . . 😉
              #55854
              Doug Wilson
                Thanks Gary,
                got parts ordered at lunch today
                Doug
                turned off?
