Home › Forum › Ask A Member › OMC parts search – does this part exist?
- This topic has 24 replies, 1 voice, and was last updated 1 year, 3 months ago by
CHUCK.
November 28, 2017 at 11:42 am #68015quote Phil B:
Nope, that is the starter bracket. Generator goes on the other side.
November 28, 2017 at 1:45 pm #68016Very rare part. It took years of searching for me to find a pair of them. I always have my eyes open for them.
Wayne
November 28, 2017 at 2:57 pm #68017quote wbeaton:Very rare part.Yes, I’m beginning to figure that out….
quote wbeaton:It took years of searching for me to find a pair of them. I always have my eyes open for them.Well if you happen to find a "spare", feel free to let me know! 🙂
November 28, 2017 at 3:42 pm #68021Phil B that is the correct side actually , but it is the manual starter bracket (rewind) not the generator bracket. Gets kinda confusing when you call it the starter bracket & don’t explain manual starter vs electric starter? Hope that helps.
Looks like the easiest thing to do would be to make a pin & install it into the bracket you have? Location may be a little tricky to find, but be creative. Maybe a little modeling clay would help find the exact location? Just my first suggestion.Dan in TN
November 28, 2017 at 4:26 pm #68022According to the 1958 Johnson Accessory catalog, the generator bracket part number is 305679 for the RDS 20. You might contact Dan Gano. I will send you a PM with his contact data. The kit p/n was 277900 for the RDS 20′
November 28, 2017 at 6:44 pm #68029Could you take a bracket without the "pointy tip", drill and tap it and then machine a pointy tip to fit? Maybe you could make a pointy tip by cutting the head off a bolt, putting it in a drill press and making the point with a file while it spins – screw it into your tapped hole in the casting and put a nut on the bolt to lock it at the desired dimension? Or drill the hole for a slip fit for the bolt and put nuts on each side of the hole? If the non tipped bracket has a big enough chunk of metal in the right place this should work. Comments??
DaveNovember 28, 2017 at 7:18 pm #68031305679 doesn’t have the ‘pointy thing". That’s the "black bracket" I showed in my photo.
I’m tending to agree: take the bracket I have & fabricate some sort of cowl locating pin. Machine something, or maybe just put in a bolt & grind down the end.
November 28, 2017 at 8:59 pm #68033The other part number in the 1958 Johnson Accessory parts book is the 377006 generator bracket. The application is for the RDE-19C. Don’t have a handle on that one.
November 29, 2017 at 1:35 am #68045quote Phil B:That is the starter side.
He’s looking for the generator side.
November 29, 2017 at 2:02 am #68047Deleted post. Screwed that one up! Sorry.
Dan in TN
