Home › Forum › Ask A Member › OMC folding motors
- This topic has 4 replies, 5 voices, and was last updated 7 months ago by
opposedtwin.
April 6, 2026 at 7:02 am #314278
Have searched for this in various ways on this forum but found very little info. Found this 1967 Johnson JHF22C 3 hp folding motor in younger son’s barn. Trying to get background info on it, such as years they were made, how many produced per year, rarity, etc. This one turns over and has compression but didn’t have gauge with me, so don’t know how much per cyl. Will appreciate any info. TIA
April 6, 2026 at 8:28 am #314293These are not too rare, finding one with a good case that isn’t damaged is rare. You must be very careful not to damage the tip of the gearcase or the unit will not lock in the folded position. Yours looks to be a 1967 Johnson with the 90 degree higher thrust gearcase. The biggest concern is the condition of the fuel tank, make sure it isn’t rusted or fouled inside. Going through the ignition, fuel systems, impeller replacement is usually all they need to become reliable daily runners. These engines don’t have much compression, you will only see about 70PSI, which is normal.
I don’t know what other questions you have….
April 6, 2026 at 9:57 am #314304
It looks to been out of service for a long time. If it still has its original its coils the covering will have failed and be falling apart. New coils are still being manufactured. Most come from China. CDI Electronics is US company that claim they make them here. They are expensive compared to the Chinese coils. You can find them on eBay if you search for – CID Electronics 183 4477. Impellers are still being manufactured as well.
April 6, 2026 at 5:24 pm #314355to service your oldy all you need is in here just download print bind locally
https://www.socalaomci.com/library/johnson_service_manual_10th_edition.pdf
as indicated coils-condensers likely shot but all eay stuff to fix on the JW type 3hp.. great kickers !
ignition points may just need a light clean -up and set at .020
lots of utubes
April 6, 2026 at 10:38 pm #314406These are not too rare, finding one with a good case that isn’t damaged is rare. You must be very careful not to damage the tip of the gearcase or the unit will not lock in the folded position. Yours looks to be a 1967 Johnson with the 90 degree higher thrust gearcase. The biggest concern is the condition of the fuel tank, make sure it isn’t rusted or fouled inside. Going through the ignition, fuel systems, impeller replacement is usually all they need to become reliable daily runners. These engines don’t have much compression, you will only see about 70PSI, which is normal.
Can you explain this issue? Which “tip” and how does that affect the folding action?
