Home › Forum › Ask A Member › OMC Cylinder Head Torque Sequence Diagram
  • #4847
    aquasonic
      I am looking for a torque sequence diagram for the 10 bolt OMC cylinder heads from the 1940’s and 1950’s. Much appreciated if someone can post one here. Thanks.
      Improvise-Adapt-Overcome
      #40996
        You always start in the center, and spiral outwards. Start with 1/2 torque for a round, then 3/4 torque, then the final torque. Every time, starting on a center bolt, and spiralling outwards.
        9……..10
        5……..6
        1……..2
        4……..3
        8……..7
        Imagine each number here is a head bolt. Rough draft, but you get the idea.
        #40997
        aquasonic
          Thanks Chris. That works!
