Home › Forum › Ask A Member › Omc controls question
- This topic has 9 replies, 3 voices, and was last updated 4 years ago by
hondaatc.
October 9, 2022 at 10:25 am #267326
Hey guys i have two boats one I’ve had about a year from the 60s with johnson controls found new cables no problem done deal .. now i have just picked up a 1957 mohawk 15 foot runabout with a 1956 johnson 30hp my question is are they different cables on the control end ? the controls definitively have a different style to the handles and housing . I did a quick internet search and the control housing has a rack style set up thanks for any information
October 9, 2022 at 10:35 am #267328Cables up through 1978 will fit your old style control. But the motor ends have the adjustable plastic nuts, which require different cable locks on the motor. 1979-up are distinctly different in that they do not have removeable ends.
October 9, 2022 at 10:47 am #267329I believe the early cables are 400 series. From ’79 are 479 series.
October 9, 2022 at 11:13 am #267330Great thanks guys for the info so just to be clear because i am a little slow sometimes they are the same cables up to 1979
October 9, 2022 at 12:23 pm #267334I’ll say yes for OMC.
October 9, 2022 at 12:57 pm #267338Great thanks guys for the info so just to be clear because i am a little slow sometimes they are the same cables up to 1979
Yes, the 400 cables fit all the pre-’79 controis. But if replacing the early “fat” cables, the locks #11 & #21 have to be changed to take the plastic adjusting nuts.
October 9, 2022 at 1:34 pm #267341An (1958) example of the old “fat” cables without plastic adjusting nuts. Locks #11 & #21 are different size.
October 9, 2022 at 6:04 pm #267355Fantastic i appreciate this so i can just change the locks on the engine to the newer ones and I’ll be good to go ?
October 9, 2022 at 6:07 pm #267356October 9, 2022 at 8:52 pm #267374Thanks a lot one step closer !!!
