Home › Forum › Ask A Member › OMC Coils (1940’s) Testing
  • #275267
      The height of the of the plug wire connection
      is a concern. If that clears it could be an option
      in motors where that isn’t an issue.
      #275273
        Aren’t these the same coils the Johnson TN-HD motors used?  Later ones had a single ground wire and should fit the Gale mag plate. Shouldn’t have any problem locating some of these considering how many TN and HD motors were built. Better yet, stop by and I’ll give you a couple!
        TN-26-Mag
        #275295
          Yes, those coils will work. I had five loose coils laying around, all tested bad
          on the secondary. No doubt, some of those came off of some
          of my Johnson T and H models!
            Those Tecumseh coils seem to be very reliable. I have messed with many of those engines, on snow blowers and lawn mowers, and have never seen a bad one yet. Even their condensers seem indestructible. 99% of the time, if a Tecumseh has no spark, it’s just that the points are dirty. They don’t produce a huge whack like OMCs, though. Maybe that’s why they last. Tecumseh spark plug gap is .025.
            #275306
              Bill, I’m not sure about the reliability of these cheap
              “knock off” coils for Tecumseh, but one can hope
              the produce spark!
