Home › Forum › Ask A Member › OMC 9.5 HP Power head
Viewing 3 posts - 21 through 23 (of 23 total)
  • #274438
    Evinrude 25
      Hi crosbyman
      It got spark on both cylinder so I did not check the electrical. I may need to remove the flywheel and clean all points and regap it again.
      #274549
      Evinrude 25
        After the first run, I check the compression again and now it has improved to 65-66 psi (let say around 5-6 psi up from the past).
        Still have the hesitation in very cyclic at low speed but it is more steady at high speed
        …. have all the electricals been worked…. especially the condensers (Crossbyman). I will have do it this weekend to see if it is the case.
        https://youtube.com/shorts/RaHZxcUP84s?feature=share
        https://youtube.com/shorts/y57k6aHXthk?feature=share
        #274553
        Tom
          That hesitation at low speed is a lean sneeze.  If the motor has an idle mix adjustment, open it up a bit.
          T
