Home › Forum › Ask A Member › OMC 6 hp–removing carb?
- This topic has 5 replies, 5 voices, and was last updated 10 years, 3 months ago by
RICHARD A. WHITE.
August 7, 2016 at 5:40 pm #4937
This is almost certainly only a parts motor as it’s apparently been submerged and then let sit. It’s a 1985.
Appears to me that it’s impossible to remove the carb without removing/dismantling the starter, because the starboard carb nut isn’t otherwise accessible. Am I missing something? Is there a way? In my (limited) experience those pinion starters are best left alone if possible.
am
August 7, 2016 at 8:34 pm #41729Nowhere near as bad as you are imagining. Remove the two screws from the top of the starter and pick it up just enough to pull it out of the lower bearing, then lay it aside to your right. Now go ahead and remove your carburetor. Don’t worry, it isn’t going to go sproinggg.
August 8, 2016 at 12:27 am #41734In the past I have taken a old screwdriver put it on the edge of the nut and give it a tap in most cases this will loosen up the nut so you can remove it. good luck Big Rich
August 8, 2016 at 1:00 am #41736That was discussed on this board back in June. Here is the link to the topic.
viewtopic.php?f=2&t=7262&hilit=How+the+hell%3F%3F
-BenOldJohnnyRude on YouTube
August 8, 2016 at 5:09 am #41749Thanks for the info, especially the thread with pics! This being a parts motor, I removed then handle, released the torsion spring tension, and took the starter and the cam follower thingy off. No problem after that except the ugliness in the float bowl. I’m beginning to think this motor may have been fed a load of water via the fuel tank.
More generally: With things opened up there was no difficulty in unsticking the motor–some spray lube and gentle tapping on the piston heads did it. The Cylinder walls look OK, though I’m sure the rings are stuck. It it was a plain bearing motor I’d think it might be run. But it seems there is very little chance the needle bearings and their races aren’t rusted, such that running would result in self-destruction. Anybody disagree, and think a full disassembly worthwhile?
August 8, 2016 at 10:01 am #41753quote Fisherman6:That was discussed on this board back in June. Here is the link to the topic.
-BenYeah that was me, Frank’s advice is spot on worked well, I also tried the screwdriver tap method and that worked too, so both are good advice.
classicomctools@gmail.com -
