Home › Forum › Ask A Member › OMC 502187 Carb rework kit?
  • #267011
      I just picked up a bunch of NOS OMC stuff that was going to get tossed out, by the place where I work. I found this box, 502187, “Carb rework kit.” It is not antique by any means. It appears to be one of the later 6/7.5/8 hp vintage carbs, with the plastic cover on top. It is an entire carburetor, plus It also has a new, tiller handle-mounted stop switch-and-lanyard assembly in the box. I don’t remember ever seeing any kind of bulletin like that. Does anybody know what this was about? I found almost nothing about it on the Web.
      • This topic was modified 4 years, 1 month ago by billw.
      #267015
        This is a rework kit for the 93 9.9-15hp models, the first year to the new design.  The kit included a new carburetor because there was no screw/mount for one corner of the plastic top cover, causing an air leak in the idle circuit.  No way to fix the original carbs, so the new carb was part of the update kit.  The original side mounted stop switches for these engines were troublesome also, thus the new stop switch.  I’m not sure if your kit is for a 9.9 or 15hp model though, perhaps the instructions in the kit will clarify.  If indeed, it is a 15hp carb, it is worth some dough, people are always wanting to “convert” their 9.9s to 15.
        #267022
          Thank you! That helped nail it down, quite a bit! There was no direction sheet in the box; but the carb itself did have a part number sticker(436780), which I found to be in a string of number changes for a 15….So that’s good I guess!
          #267037
            Yeah buddy!  That carburetor is worth its weight in gold these days.  And, that stop switch is an expensive part as well.
