Home › Forum › Ask A Member › OMC 225C help
- This topic has 7 replies, 5 voices, and was last updated 4 years, 3 months ago by
Don.
July 19, 2022 at 6:21 pm #263232
Greetings, new to this forum and these engines. Not sure this counts as antique, but I recently obtained an OMC 225C engine (spec 489400, SN 02284) that I’d like to find service info for. Not sure how old it is, maybe 84 from SN? Would like to know the plug type, fuel/oil mix ratio, wiring etc. Thanks for any clues you might offer!
July 19, 2022 at 6:42 pm #263234What type of OMC engine is this? Does it have a model number? Perhaps you can post a picture or two….
July 19, 2022 at 8:12 pm #2632422 cylinder, 2-stroke, horizontally opposed, all specs in original post, nameplate photo attached. Thank You!
This reply was modified 4 years, 3 months ago by
shektek.
July 19, 2022 at 10:34 pm #263252Is it safe to assume it’s an outboard motor?
May seem silly, but snow mobile and sled websites come up with a quick look up of “omc 225c” on the innerwebs.
If indeed it is an outboard (and I can’t tell from the photo), marineengine.com says it’s a 1992 225 hp which is a v6. Which it ain’t.
Anyway, send pictures of the entire machine.JMGP
July 20, 2022 at 5:38 am #263257Is it safe to assume it’s an outboard motor?
Anyway, send pictures of the entire machine.I think you’re right…it’s a snow mobile engine. I see what seem to be exhaust runners on the bottom.
July 20, 2022 at 7:44 am #263262Sleds! The one I have was retrofitted for an ultralight airplane. I found that 225 HP reference everywhere… Attaching another photo, exhaust is off. Cylinders look good, need to clean carb, find the right plugs and oil mix, then test run. Thanks for taking a look!
July 20, 2022 at 7:56 am #263265July 20, 2022 at 11:03 am #263280Well, OMC had several divisions back then, and this is not from an outboard. Looks to be either out of a snowmobile or a cushman vehicle.
