Home › Forum › Ask A Member › Oliver/Tescher fuel pump question
  • #8118
    rco
      I am going through a 5.5 Oliver that hasn’t run in years. The fuel pump was leaking, so I took the cover off. There was only a diaphragm between the two halves, no check valves, springs, etc. What all am I missing?
      #64270
        I believe the diaphragm itself acts as the check valves.
        I had the same question when I fixed mine!
        rco
          Thanks for the info. Seemed too simple to be right compared to any other pump I’ve had apart.
