Home › Forum › Ask A Member › Oliver 6 HP fuel pump help needed
- This topic has 14 replies, 9 voices, and was last updated 2 years, 9 months ago by
huntleybill.
January 24, 2024 at 8:01 am #284271
I have installed those round B&S pumps ….not saying they don’t work but the subject came up a few years ago on this board.
Something to do with the brass mesh screen over the pulse chamber of the pump allowing the heavier fuel-oil mix present in the pulse line t o ooze out the mesh.
actually.. if I recall correctly conclusion on the B/S round pumps was that they are better suited to 4 stroke application such as small engines for garden tracors/ lawn mowers etc…
For 2 stroke the square Mikuni pumps are better or the basic square OMC pump if it can be adapted so the crankcase pulse can be fed to it.
January 24, 2024 at 12:26 pm #284281Ollie’s Parts Counter in links offers fuel pump diaphragm material.
January 24, 2024 at 12:56 pm #284282I have installed those round B&S pumps ….not saying they don’t work but the subject came up a few years ago on this board.
I’ve had mixed results with the B&S style fuel pumps with the brass screen on my outboard projects. A couple times they worked fine but my last project it didn’t work at all. I’ve never had a problem when I used a Mikuni pump.
"Every time you remove a broken or seized bolt an angel gets his wings."January 24, 2024 at 4:39 pm #284287Before you give up on the original pump, have you talked to Roger Soderstrum… Mr. all things “Oliver”
January 26, 2024 at 6:12 pm #284378Thanks Geary. I bought one. I just need to put it on. Or mainly figure WHERE to put it on!
