Home › Forum › Ask A Member › oliver
- This topic has 8 replies, 4 voices, and was last updated 6 years, 6 months ago by
frankr.
April 5, 2020 at 3:50 pm #199259
i have an oliver outboard model J2 51/2 hp
help on to setting points
this motor i have a scintilla magneto (*Bendix)
new coils points condensers
on this model there are NO holes in top flywheel
also to which cylinder is number one ?
thank you
ralph simmons
ralphsimmons1234@gmail.com
1-315-923-7828April 5, 2020 at 6:00 pm #199300If there’s no holes in the top of the flywheel, you’d have to remove the flywheel
to set the points. (.018)
When you have the flywheel off, you should be able to tell which coil goes to
the top cylinder.I have an email address in my notes for they guy that use to ? sell parts
for Olivers…… not sure it’s still good.
dan@oliveroutboardfixation.comPrepare to be boarded!
April 5, 2020 at 6:07 pm #199301April 5, 2020 at 8:24 pm #199311here is photo of my plate after i had to re do it completely
was on my oliver 1956 5 1/2hp.
in my photo i labeled it to help with getting it set up
front of motor / coilsi am not sure where coils go to which spark plug
as there no plug wires went i got
hope you can help here
thank you ralphApril 5, 2020 at 8:31 pm #199313The coil on the top side of (Port side) your photo should go to the upper cylinder.
April 6, 2020 at 7:29 am #199320ok thanks to all for help and reply’s to my questions
ralph simmonsApril 9, 2020 at 5:45 pm #199523set your spark advance to fast. and note which set of points is starting to open. those points connected to the coil will go the piston that is at or near TDC or top dead center. Works for me.Jim
2Fast4Me
April 20, 2020 at 8:39 am #200576April 20, 2020 at 8:35 am
#200574
Edit Replyhello i have Low compression 60/90 1952
will not start, i could get to fire with starting fluid only
any one have rings or head gasket
thinking it could be a start ?
to fix problem
ralphsimmons1234@gmail.comApril 20, 2020 at 2:50 pm #200597Don’t know if this applies to your motor or not, but I haven’t forgotten the Chris Craft/Oliver that drove me nuts about 60 years ago. Like yours, it absolutely refused to start or keep running. So, my question to you is, have you or anybody else had the carburetor off? The reed block is sealed to the crankcase by a big o-ring. When you reinstall the carburetor you must tighten the nuts hard enough to squish that o-ring enough so that the reed block bottoms out in the crankcase. If it is not bottomed out, the crankcase fuel/air charge simply passes up and down between the upper and lower chambers. Whether or not it runs at all, or just poorly, depends on how close to bottoming out you got that reed block.
Those can be great running motors.
