Home › Forum › Ask A Member › Old omc fuel tank with only a fuel line connector
  • #295864
    TJ Brandon
      I have an old omc 3 gallon fuel tank as seen like the picture below with only a hose fitting on top. How can I make this a quick disconnect to use a standard OMC connector? I want to use it as a backup tank and disconnect from my normal 6 gallon tank which has the omc connection.
      #295867
        just add the fitting you need.
        #295869
        Steve D
          I don’t know if you can unscrew that pick up assembly and screw in one that has a male connector. I’m not sure I’ve seen one of those on the 3 gal. So you have to attach a short length of hose to the tank and attach a male connector to the other end. Then your female on the squeeze bulb assembly will be able to quick disconnect.
          connector2
          connector1
          #295873
          TJ Brandon
            That second picture you posted helps. I didnt realize they had one available with a valve that would seal when the fuel line was remove. Thanks
            #295874
              use a hose from tank and new fitting.
