Home › Forum › Ask A Member › Old Johnson Sea Horse
  • #1256
    rayr
      I picked up a Johnson and not sure what I have. The serial number is 644287, this motor is in such original shape my wife even appreciated it. Any info woul be great.
      New member
      #14268
      RICHARD A. WHITE
        Pictures? That serial number says 1948…..
        classicomctools@gmail.com
        #14273
          We need the model number to identify the motor.
          #14302
          rayr
            I have looked everywhere for model number, except under the recoil starter. Do I need to go there?
            Why is it every time I go to the shop there is another motor? Do they breed in the dark?
            RayR
            #14305
            mr-asa
              Throw some pictures up?
              #14309
              legendre
                Depends on the year of manufacture, but model no. is typically stamped (sometimes crudely) on a raised boss or other flat-ish surface near the bottom of the power head case, aka the "engine block".
                Typical 40s-50s models would be "HD25", "TD15", TD20" etc. Two letters + two numbers is typical.
                Unless there is a separate model / serial plaque, it’s going to be stamped directly into the case 99% of the time.
                BTW – Howdy friends, old & new! I was totally flummoxed when I couldn’t find the forum.. just figured out what went on with the server loss, and got re-regged today!
