Home › Forum › Ask A Member › Oil slingers…ooops no it is not :(
  • #4987
    RICHARD A. WHITE
      Love them little buggers…..
      1953 Evinrude Super Fastwin 15 hp, model # 15012
      Parts list I have says part should be.. 301857
      I have one with part number 307576…..
      It fits the crank, but is it right?
      Thanks
      classicomctools@gmail.com
      #42131
        PN 301857 is not an oil slinger, that is just the washer which contains the spring on its top side.
        Also, the model 15012 Fastwin doesn’t use a slinger, it has a carbon seal and o ring assemble on the top of the crank. All the ones that I have seen anyways, perhaps im wrong and there is a variation of the 15012 with a slinger that I haven’t seen before?
        Then a 302594 washer sits on top of the carbon seal assembly, then the 203250 spring, then the 301857 washer, then the points cam on top of that.
        #42132
        RICHARD A. WHITE
          So the carbon seal is under that bottom washer?Ok I see the Carbon seal…I had oil on the points…now to get the carbon seal out without breaking that fragile housing…grrr
          #42134
            Correct. This should help.
            #42138
            RICHARD A. WHITE
              I got that, apparently I must read THE WHOLE DANG PAGE…LOL
              #42139
              RICHARD A. WHITE
                That shows 2 o-rings?????
                #42143
                oltimer
                  quote Richard A. White:
                  Richard, that is correct; but one goes around the bearing. Every one that I had to split the casing open before because of excessive oil going by that o-ring; was cracked. You might have to go in there and do it too?
                  Jer
                  #42163
                    Yeah as jer stated, that larger #11 o ring goes around the bearing. You can see the groove for it at the bottom of the bearing in the pic. The #10 o ring seals the inside ID, and goes in the carbon seal. I don’t think there is anyway to do it without splitting the cases sorry.
