Home › Forum › Ask A Member › Oil Seal Scott Atwater
  • #1087
    mercuryman
      Anyone know the part # or seal size for a 1955 7.5 HP Scott Atwater to crankshaft seal. And how about a place to order seals by size.
      #13206
        Tell me, Are we lookin for the top or bottom crankshaft seal?
        #13210
        mercuryman
          TOP seal
          #13232
          jim-moffatt
            If you search the SKF site for Chicago Rawhide they have part numbers for most seals. You must have: ID OD and thickness.
            These you can get from the old part.
            I cant find the link right now. Then NAPA sells seals with the same part number but starting with NOS (NAPA oil seal).
            I have found several Scott seals this way.
            #13238
            mercuryman
              Thanks, the SKF site didn’t return a part # but the Emerson Bearing Co. site gave me a # and O’Riley has one, National 254270 .75 shaft. – 1.124 OD
