Home › Forum › Ask A Member › Oil and Mix for 1916 Koban
  • #235933
    limnos
      Finished my working restoration of my 1916 Koban. Intend to try running at Tomahawk. What would be the best oil to use for the mix and what ratio? I have never run a Koban before. Restored it to be a “runner”, new gaskets, corn head grease on water pump gears, etc.
      Koban-1916-UW-Ex-Restored-1
      • This topic was modified 5 years, 7 months ago by Mumbles.
      #235935
        Well, I couldn’t tell you what the oil mix is, but I can tell you that is one of the most OUTSTANDING antique restoration projects I’ve seen! I would be afraid to use it! Congrats on a magnificent job.
        1982 Evinrude 25hp
        #235937
        LLOYD LAUTNER
          It’s beautiful!!!!!
          #235940
          BROOK E. NEWCOMB
            Excellent job looks Great!
            I have a 1915 Koban 1/2 pt per gallon has served it well.
            I like Pennzoil two cycle tcw 3
            Opinions will vary.
            Respectfully,
            #235959
              I think I was once told they like a heavy mix, like 8:1, as they have iron pistons running in iron cylinders. Not sure.
              #235961
              BROOK E. NEWCOMB
                Nice to see another one with underwater exhaust!
                I have a 1918 with underwater exhaust an option
                That you rarely see.
                Respectfully,
                #236014
                PM T2
                  Beautiful motor. You can run it with the fuel/oil mix as Brook suggested.
                  I myself prefer to run these at 8:1, but that’s just my personal preference/prejudice.
                  Hope it helps.
                  Best,
                  PM T2
                  Kobunn Special Interest Group Leader
                  #236388
                  George Emmanuel
                    You will find that you’ll need an extra large amount of space to turn the boat when underway, and even then, it may not turn where you want it to go. When the rudder is turned, the prop wash bypasses and goes straight out making it difficult to turn. Wasn’t a real efficient design, but the motors run well! Beautiful restoration!
                    George
                    #236409
                    limnos
                      Thanks for the info. In the past, I was told I might want t use 4 stroke oil (As they did in the period), but two stroke is OK? I assume non-synthetic? I have heard synthetic is just too thin for these older motors.
                      #236411
                      limnos
                        I know you need a buzz coil for each cylinder, but do you also need a separate battery for each buzz coil, or can you run them both off a single battery. 6v lithium type?
