Home › Forum › Ask A Member › Ohio sticker remove
  • #3487
    mercuryman
      I have a Ohio sticker I want to remove what is the best way.
      RICHARD A. WHITE
        Wife uses "Goof Off" in her craft hobby…. might work…
        classicomctools@gmail.com
        #30811
        beerman57
          T
          #30812
          Steve D
            You could try a little heat, like from a hair dryer, to soften up the glue, carefully get a snap-off or X-Acto knife under one corner, slowly peel away sticker using more heat as needed, clean off glue residue with WD-40.
            #30813
            reynolds49
              I use a heat gun to remove decals,
              keep the heat gun moving and apply just enough heat to warm the decal but not harm the paint.
              when the decal gets hot I peel up up a corner and pull gently. you will need to heat and pull several times to get the decal off.
              when the decal is removed I use 3m adhesive remover to remove the glue. just follow the instructions on the can
              #30814
              david-bartlett
                +1 for the heat gun or hair dryer!
                #30815
                mercuryman
                  Thanks, I will try heat.
                  #30817
                  DAN ANDERSON
                    I’m in on all the suggestions, but have found these plastic razor blades a big help. JasonH put me onto them and they are great for anywhere you don’t want to damage a surface. You can get them at any hobby store, Michaels, or off Ebay in large quantities. Give them a try!
                    Dan in TN
                    #30824
                    marty-a
                      ( Goo gone ) available in grocery stores. works great and will not damage the paint
                      #30833
                      jerry-ahrens
                        That’s a nice motor. Is it an original? It’s hard to find a Chris Craft with the original paint in that good of condition. The idle quality of the Challenger motor is one of the best Iv’e ever heard.
