Home › Forum › Ask A Member › Odd Speedster
  • #324414
    HARRY D. NICHOLSON
      A battery advertisement. March 1928.Elto1928MarchPBoddcropped
      #324425
        Ignition powered by a Columbia Hot Shot Battery
        columbia-hot-shot-battery
          Is it a Quad? Looks like a Speedster to me. ???
          #324456
          HARRY D. NICHOLSON
            Thanks for the correction Tubbs. I’ll try to edit it.
            #324463
              You really had me confused there Harry. I know how knowledgeable you are about all the early motors. What was I missing?????
              #324491
              PM T2
                I had to look twice because the gas tank initially makes you think its a second set of cylinders, but its just a tank.
                I find the appearance of the Elto logo in the area of the coil casing to be a bit interesting. Advertising dept trick maybe.
                PM T2
                #324512
                  It took more than a second look for me. My eyes went right to the coil. I’m thinking, that is odd. A Quad with only a single coil. When I copied the picture and expanded it to see the coil wiring better, I realized it looks more like a Speedster. As Harry knows sooooo much more about this stuff than I do, it could be a special motor, till he said it wasn’t.
