Home › Forum › Ask A Member › OB64A Neptune Magneto Blues Review
Viewing 10 posts - 11 through 20 (of 25 total)
  • #173200
    JOHN D.
      The Waterwitch twin and the Lauson twin both used that same coil. Or you could use a coil from an older 4 cylinder motorcycle with a 6 volt battery.
      #173209
        Thanks, good to know about the Lauson coils. I have two, one for parts, so there’s a chance I cold rob
        a coil from one!
        JOSEPH BRINCAT
          The Lausons are notorious for melting coils. Air cooled motor run too slow for too long a period is supposed to be the culprit. I know for a fact that the John Deere pony coil retro into the Lauson Eisemann 72 mag will work. Member here in Great Lakes has done it successfully.
          #173216
            Joe, good to know the pony coil I bought will fit in the 6 hp Lauson. I’d have to butcher
            the mag plate to get it to fit the Neptunes.
              • This reply was modified 7 years, 7 months ago by Tubs.
              #173232
                Thanks Tubs, looks like there’s more options that I imagined.
                I’m guessing the Harley coil is a little more spendy than the
                Onan repo coil, but it sure has more class!
                  Update- I robbed the coil from the OB34A 4 hp Neptune, and put it
                  on the OB64A 6 hp Neptune, and now appear to have great spark!
                  It’s ready to try out, but that 10″ of wet sloppy snow from yesterday
                  is raining off the garage roof, right over the test barrel. Suppose to
                  be 20 degrees warmer Tuesday anyway.
                  I’m “re-thinking” about trying the pony coil, but now for the 4 hp Neptune.
                  To get the plug wires to exit the coil and through the mag plate, I’d
                  have to pull out the grommets and notch out the mag plate in the area
                  shown in the photo. (hopefully neater than my free hand drawing!)
                  Perhaps it wouldn’t be too much of a butcher job, and if it
                  actually worked, I’d be happy. I’d still have to further whittle down the
                  lamination, as the Pony coil hole is 7/16″ square.
                  Only hesitation is that the B&S coil swap attempt was a total failure,
                  and I have no idea why, less it’s the difference in design of the laminations.
                  Not really sure what a JD Pony coil laminate look like either.
                  DSCN7728
                  DSCN7729
                  DSCN7730
                  DSCN7727
                    DSCN7728-1
                    DSCN7729-1
                    DSCN7730-1
                    DSCN7727-1
                      #173271
                        I didn’t even notice the link before. That’s pretty cheap.
                        I started altering the mag plate and the lamination
                        to mount the pony motor coil. Stay tuned to see if
                        that works better than the B&S coil!
                        Click on the eBay Link I Posted
                        $15.00 + $8.75 Shipping.
