Home › Forum › Ask A Member › non splitting l.U. on a 9.5 Sportwin ????
- This topic has 8 replies, 4 voices, and was last updated 9 years, 5 months ago by
JACQUES.
May 22, 2017 at 7:51 pm #7094
my new to me 9.5 which came with a CD15 plate π― …. has a solid gearcase (non-splitting) like they began around 1974 …an up wards on the 9.9 hp version
the engine faceplate on the cowl says 9.5 but the solid gearcase speaks 74 and up & according to parts diagrams on that site we all look at
it is a 9.9 hpI never took one of those l.u. apart . I found a few drops of water in the l.u.
If sealing the l.u is to complicated I may just refill with fresh oil on occasionany special procedure/tools to reseal these solid bodied L.U. … & their hard to access gears and seals …
meanwhile I go surf utube….
update#1.. I looked at parts diagrams they show a prop with rubber drive core yet my engine has a standard old style drive pin shaft
it is like it has one foot in the pre 74 world of split gear cases & drive shaft and one foot in the post 74 solid gearcases yet it drives the prop with a drive/shear pin about .185inch diameter by 1.5 inch long
May 22, 2017 at 10:10 pm #58164Is the drive pin near the gearcase or toward the threaded end of the driveshaft? Any way to see a picture of that gearcase. I’ve never seen a 9.5 that didn’t have a split gearcase.
-BenOldJohnnyRude on YouTube
May 22, 2017 at 10:36 pm #58166the drive pin is near gear case at he back of the prop …
the drive shaft thread hole is for the cotter pin to lock in the prop plastic nose cone
solid gearcase is typical on 74s and up
motor came with a full circle prop protector bolted to the cavitation plate and tip of the keelJoining AOMCI has priviledges π
May 22, 2017 at 10:45 pm #58167May 22, 2017 at 11:01 pm #58170May 22, 2017 at 11:04 pm #58172May 23, 2017 at 12:01 am #58176It’s a regular 9.5 lower unit. Nuttin’ special.’
May 23, 2017 at 12:06 am #58177In that first pic, there seems to be the remains of a seam… Could the PO have welded the case halves together? Could try scuffing some paint off and look for welds, especially the underside where the screws would be…
May 23, 2017 at 12:16 am #58178bad day today … clothes dryer timer blew….
found the problem … me π
Kerry sharp eyes spotted that seam… in the photo
l.u. is so filty looking down on it….. i did not see those screws …
now I can seal it π
