Home › Forum › Ask A Member › Noise at Idle
- This topic has 15 replies, 9 voices, and was last updated 8 years ago by
David Stanton.
October 28, 2018 at 1:44 pm #85096
At this point, it’s me against the Buccaneer! Appreciate the fine advice. I hate to remove two powerheads and swap two lower units. One tiny other piece of information, if I rev the engine in the test tank (fairly high rev for a few moments) it seems the ticking goes away at idle for a few seconds. (may be my imagination or hearing) I’m going in!
One question though, I have always used Permatex Anaerobic Flange Sealer when assembling the crankcase halves. I have run out of this stuff and I am wondering if VersaChem Prime Seal Type 3 Aviation sealer will be satisfactory for this application.
Thanks again for the interest and help.October 28, 2018 at 1:48 pm #85097🙁 tubs… that is exactly how my first 20hp Merc died in the late 70’s ….nice hole punched on the side
not knowing any better in those days I gave it away as junk instead of fixing it
October 28, 2018 at 2:43 pm #85099quote Drifter:if I rev the engine in the test tank (fairly high rev for a few moments) it seems the ticking goes away at idle for a few seconds.What shape are the drive and crankshaft splines in? Worn splines on either might cause the ticking noise.
October 28, 2018 at 5:36 pm #85110When I resealed the lower unit I also checked the splines when I greased them. They looked good. I will check them again when I pull the power head.
October 28, 2018 at 8:35 pm #85116A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
This reply was modified 8 years ago by
Tubs.
Tubs.
October 29, 2018 at 3:54 pm #85166quote crosbyman:🙁 tubs… that is exactly how my first 20hp Merc died in the late 70’s ….nice hole punched on the sideI have a 1976 20 HP Merc that had a ticking/rattling noise at an idle and it got worse with speed. The lower crankshaft bearing was coming apart and a couple of the balls from the bearing found their way into the lower cylinder through the intake port. These were being slammed back and forth and did a number on the top of the piston, which I replaced along with the bearing. Enough metal was knocked off the raised portion on top of the piston to unbalance the motor, but cylinder walls were amazingly good. I haven’t run that motor for many years because it seemed every time I ran it, something else broke. I bought it from a friend, so know the history – it has mega-hours of fishing on it.
Dave -
