Home › Forum › Ask A Member › no washer behind castle nut on trailer bearing!
  • #1850
    opposedtwin
      I found no washer behind the big castle/spindle nut on my boat trailer as I was taking it apart to put new bearings in. they should be there, correct? the drawing on the reese kit has it on there. would any NAPA store carry them? are they a special size?
      #18837
        look at the cotter pin hole and see if it would take one. I have had both. the one without would not accept a cotter pin IF I used a washer on it.
        #18871
        opposedtwin
          I reassembled and there is enough play make me believe there should be some washers in there. who would sell/stock washers like these? they have to be big but are mostly hole. I have another pair from another trailer so I have a reference. I tried the local auto parts store (weaver) and they can’t get them and don’t stock them. etrailer.com has some but they have a flat edge on the round inside that must be for a spindle with a flat spot.
          any ideas? probably will have to try McMaster carr.
          #18872
          legendre
            Is there a shallow axial groove cut through the threaded portion of the spindle?
            That would be a dead giveaway, as the slot provides positive locus for a washer with a matching tab.
            #18873
            opposedtwin
              no there’s not legendre. I have seen those before on cv shafts, etc
              #18880
              opposedtwin
                etrailer.com has them for $0.49. perfect!
