Home › Forum › Ask A Member › No Maintenance, No Problem
  • #6477
      Today I removed the thermostat out of the ’60 Evinrude Lark with the scored cylinder walls I had posted earlier and guess what I found. First, as expected, a bunch of salt corrosion.
      Then, after cleaning the stat up a bit, there was the build date, Sept of ’59. This means the motor had never had the stat replaced in 57 years! OMC quality or owner neglect?
      #53911
      PugetSoundBoater
        Did you test it to see if it still works after cleaning? looks pretty good all cleaned up.When i have found an old t stat, it comes out in 2 or 3 pieces.
        Robbie Robertson
        #53913
          Yeah, I had it working. You can see where I soldered it back together after buffing everything inside but I think putting it in the microwave killed it.
          #53917
          PugetSoundBoater
            quote Mumbles:
            Metal and microwaves don’t play well together
            Robbie Robertson
            #53922
              I should have mentioned the t stat was in a plastic container half full of water. It works OK that way.
