Home › Forum › Ask A Member › NIce 41 HandiTwin Mag Plate
- This topic has 7 replies, 4 voices, and was last updated 2 years, 6 months ago by
T….in Wisconsin.
March 11, 2024 at 10:05 pm #285830
Another Motor found its way to the back of my truck.
Looks to be in good shape and all original.
First Elto that I’ve popped the hood on.
Mag plate & flywheel are in great shape, was it common to finish these in black or was this done afterwards?
Carb & poppet valve are clean and free as can be.
Feeling good about this one. I’ll be tank testing real soon.
T.. in Wisconsin
March 12, 2024 at 9:00 am #285845I’m thinking “factory” on the black coating…… seen several like that…..
but never one so “clean” and in that nice of shape. Have fun!Prepare to be boarded!
March 12, 2024 at 9:03 am #285846Here’s my 1940 magneto……
March 12, 2024 at 10:10 am #285850I believe that the “black” is not just the usual paint but rather a bitumen (tar) based product intended for corrosion protection and damp proofing. I suspect that if you warm it up a bit you will find that it softens.
March 12, 2024 at 10:14 am #285851
If you don’t have spark after cleaning the contacts
take the points apart and clean the individual parts.
Those sparkplug boots look to be after market from
the time. Possibility Bakelite. I’d be surprised if
you could find another pair of them.
TubsA "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
March 12, 2024 at 2:24 pm #285870Agree with your assessment Tubbs the boots look in too good of shape to be original.
Correct again they are Bakelite or a durn good imitation.
The rubber plug collars do look original as well as the tiller grip.
Carb components look good. I’ll coat the float while I have it apart.
Motor doesn’t appear to have seen much lake time.
March 12, 2024 at 2:25 pm #285873Very light coating, good idea.
April 17, 2024 at 4:02 pm #286797Handitwin tank test results.
Starts easily now, still need to work on the slow idle, asking for input.
Still using the older condenser, plugs & plug wires & boots.
Seem to be a bit smokey, mixed 16/1 would 24 / 1 be safe?
Ran out of gas at the end of video.
Thanks go out to everyone for their input and advice.
T..
