Home › Forum › Ask A Member › Newly acquired Johnson Jw-10 needs Carb Rebuild at least
- This topic has 7 replies, 4 voices, and was last updated 3 years, 2 months ago by
JACQUES.
August 27, 2023 at 7:50 am #279817
Good day,
Just acquired a Johnson JW-10 (Actual Model and Serial number JWW100 & 1202121) with a carburetor that leaks fuel. I am looking for links to repair manuals and
videos on this carb rebuild. Trying to collect all information I can before I take her apart. Suggestions for a new AOMC member is appreciated.
Mike
August 27, 2023 at 8:32 am #279821simple standard carb …leaks are usually related to float….. inlet needle…. gaskets…. and packing on the needle (lower one)
http://www.leeroysramblings.com/OB%20carburetor_repairs.html
1952-54-Evinrude-Lightwin-3-Owners-Manual.pdf (aomci.org)
great motors btw… check compression ….the head gasket sometimes blows in the mid section.
August 27, 2023 at 8:47 am #279822Crosbyman,
Thank you for the information. Looking forward to getting her running !!
Mike
August 27, 2023 at 10:43 am #279827It is almost a guarantee that it needs new coils. Unless they have already been replaced.
August 27, 2023 at 1:57 pm #279836what to expect under the flywheel … nothing complex or serious after you do a few 🙂 change condensers and the plug wires and boots replace impeller to !!
August 27, 2023 at 2:01 pm #279838Partially took the carb apart and found that the needle controlled by the float needed a little coaxing. After putting her back together, got her running on two pulls. My outboard water test tank sprung a bad leak so I quickly closed up shop for the day. Once I get to a reliable tank I will try to run her for awhile and do some fine tuning as needed. If I do need to go further the coils will most likely be in her future.
Thank you,
Mike
August 27, 2023 at 2:06 pm #279839Well maybe it was serviced at some point and the ignition was done. The lower unit on that JW looks brand new! So clean compared to the cowling . Do you think that the lower part has been re-painted?
August 27, 2023 at 5:28 pm #279840they get hot running in a tub…to many bubbles generated from the prop……………… so run it slow and keep an eye on the temperature !
install the little pull down spring on the needle…!
