Home › Forum › Ask A Member › New Toy CD-12 Tank Cleaning question
Viewing 8 posts - 51 through 58 (of 58 total)
  • #41511
    fisherman6
      Ya, I get that. Get to it when you get to it. I’m wondering if something is sticking in the check valves like Dave said if the primer isn’t pumping. We’ll get it figured out eventually. Your tank has the aluminum button, right? When you take it apart again make sure the washers that go on either side of the diaphragm are oriented with the curved side against the rubber. Also make sure the check valves are moving freely and are able to seal against the seat. Does the button feel like it has any resistance at all other than the spring? I have another one of these I need to rebuild too. If you get stuck, I will get into mine and I can get some pictures as I go.
      -Ben
      OldJohnnyRude on YouTube
      #41516
      bullie
        Maybe it is the check valve. I will have to take a look at it. I don’t remember much about it.
        #41807
        bullie
          I took the 55 5.5 out this afternoon. I couldn’t be happier. It runs better than a new one. It idles down to nearly nothing. Happy. Happy. Happy.
          #41830
          fisherman6
            Great to hear! Glad it’s running like a champ.
            #42326
            bullie
              Ok guys. I took the tank apart again this evening and gave it another shot. Apparently, I had something installed upside down or something. I sat down with the parts breakdown and was very careful to get things oriented correctly. And go figure, it works fine now. Thanks again for the help everyone.
              Looking forward to fishing with this one.
              #42329
              david-bartlett
                Great Job! Another pressure tank success story.
                #42334
                  Bullie
                  That CD12 is one fine fishin motor ❗
                  Steve A W
                  #42335
                  fisherman6
                    Glad to hear you got your tank working right Mark!
                    -Ben
