Home › Forum › Ask A Member › New Toy. 1951 Evinrude 7.5hp Fleetwin
  • #30619
      Oh wow, you got lucky. Those coils have been replaced and should be just fine. But tuck the ground wires back so there is no chance of rubbing on the flywheel hub.
      #30648
      reivertom
        I wouldn’t replace a thing…..just clean and adjust the carb, check the fuel lines and start cranking. You might get lucky and have a good runner "out of the box"..
        #30652
        Leon
          +3 on that. Your ignition system looks great. Clean and adjust the points and call it good.
          #30653
          david-bartlett
            Nice little stand too!
            #30657
              Are those the tall 581419 condensers in it? The new replacement coils should be matched up with the short 580321 ones.
              #30723
              scoot
                Thanks guys.
                Mumbles. The condensors in the motor are taller than a new kit I have for a BigTwin.
                What happens if you put shorter condensers in?
                Anyone know flywheel nut torque specs?
                #30750
                  Your new condensers should work just fine. Torque is 40-45 foot pounds.
                  #30755
                  Steve D
                    When I looked up your model number it said 1951-52 so I included the ’52 ads also.
                    image url
                    free upload image
                    upload an image
                    #30768
                    scoot
                      Great ads Steve D. Thanks.
                      Found one unfortunate situation on the motor. Lower end gear case had water in it.
                      Drained it. Swabbed out what crud I could with Q-Tips and added new gear oil.
                      Scoot
                      #30772
                        Oh yeah, that motor has those funky seals without a metal shell. I suppose new ones are ok, but old ones prone to leak. I guess 65 years qualifies for "old".
