Home › Forum › Ask A Member › new (to me) motor!
  • #924
    opposedtwin
      evinrude 3012-11978 makes it a 1953 3 hp. cl find for almost nothing ($25)–even a blind squirrel gets a nut now and then!! ๐Ÿ˜†
      no spark in the top cylinder but it started very easily and ran it on the bench for about 10 seconds before I shut it down. compression is only 75 lbs–both top and bottom. what would be ideal, acceptable, etc? 24:1 ok or should I go with 16:1 due to the age and bushings rather than bearings?
      the starboard side lower cowl looks like it’s been wollered to accept an aftermarket petcock on the fuel line? it appears to be the "in line is fine" type rather than the ball cock type. thoughts?
      the anti-cavitation is broken off. how will this affect performance?
      i’ll have to get a good used coil and replace the bad one but other than that and a new impeller, it should be a keeper.
      power head not painted, eh? looks like some of the red primer still on it though. thoughts?
      scott
      #11981
        just tune* it up and try it …my 3038 was $25 also…nothing broken but lots of surface bumps fixed with Bondo and paint
        carb kit, impeller coils points etc … the usual stuff and clean the tank, 2 tank vents under the screw washer (look closely) and the tank filter on top of the fuel shut-off but it is likely gone anyway since the original valve was replaced .
        http://www.outboard-boat-motor-repair.c … une-UP.htm
        not much to do about the cavitation plate…. maybe a used gear case can be found cheaply
        Joining AOMCI has priviledges ๐Ÿ™‚
        #11982
        kees
          International Member
          well that don’t hurt $25
          and with a bit of extra oil mix ( no detergent ) you can push up the compression a bit
          I don’t know what was recommended but 1:24 sounds OK
          my 2c thoughts ๐Ÿ˜Ž
          #11989
          SCOTT BOGUE
            That old survivor deserves to be out on the water and making smoke again. I don’t think the broken cav plate will be a problem unless exhaust gases get into the propeller.
            Check to be sure that there is good lubricant in the lower unit.
            Go for a new coil if you need a coil. Jim Judkins has the Prufrex (German) coils. Not expensive. Worth the cost of new.
            From the look of your pressure tank collection, you know your OMCs.
            #11990
              That broken exhaust outlet might be a little noisy, but won’t hurt performance. The 3 bladed prop is low pitched. It can over rev on a fast canoe.
              #12000
              outboard315
                I would check the points, the other cylinder may come around with some sand paper. Napa sells the correct petcock if you wanted to replace it. Other than that it is a nice motor for the price. The compression is about right for these motors.
                #12032
                  ….. " Napa sells the correct petcock if you wanted to replace it."
                  that NAPA petcock model is ok for the 2hp it is a 90 degree valve handle pointing down
                  the 3hp needs a straight valve with the handle on the side to exit the lower skirt housing
                  unles of course they now sell a side valve.
                  #12033
                  20mercman
                    I think that I may have a lower unit for that if you’re interested.
                    Steve
                    #12035
                    jerry-ahrens
                      Be sure to use 16/1 ratio on that one, originally called for from the factory. I may have a set of lower cowls for that one to, I’ll have to check.
                      #12038
                      archangel
                        I’m curious to know what the Batman-shaped tool on the tool board is for. I don’t have one of those, Scott.
