Home › Forum › Ask A Member › New to AOMC with a 1963 mercury 200
Viewing 10 posts - 1 through 10 (of 32 total)
  • #174654
    nicholas soper
      As stated I’m new to AOMC and to outboards in general although I’ve owned plenty of old machines through the years. I have inherited my grandfathers 1963 Mercury 200( serial 1593204) and the accompanying 14 foot Starcraft from the the same era. I remember riding in it as a kid, but I’m pretty sure that it has been sitting in the shop at his house for the 15-20 years since then. I want to revive this motor and go for a rip across the lake again, but I know there’s probably a long road ahead of me. I’ve acquired an old copy of the Mercury factory service manual for pre-65 motors and that has been very helpful. My first attempt to start it showed me that I had no spark on the bottom cylinder.
      I removed the condensers and attempted to figure out how to “test” them with a multimeter, which I have now learned is mostly futile unless I could hook them up to a MercOtronic to load test them. The coils on this engine are riveted to the aluminum stator plate, so I really don’t want to remove them without justification. Any thoughts on the next steps to take on troubleshooting the lack of spark?
      I have attempted to order a pile of parts(impeller, lower unit seals kit, carb kit, fuel pump kit, condensers) from Oldmercs.com but they are in no hurry get them shipped. I’ve since found much of the parts for this engine on eBay, but not ordered any since i don’t want duplicates at this point.
      #174655
      20mercman
        The 1963 200 is a real icon motor for Mercury. It is one of my favorites! (mine is in my avatar) They were a transition motor for Mercury, first year going back to full gear shift, last year of the cloud white paint, and the large cast Mk-28esk top cowl. A great looking motor and great performer.
        As for the issues, you really can do a lot of testing with ah ohm meter. According to your serial number, yours should have the new style Phelon magneto. These are good units. The points need to be clean! Clean!!!!!!! Testing them with an analog style ohm meter works best. You have the correct service manual. it should help with this. Also, the water pump impellers are hard to find, but you can use one for a MK-25 and file the key slot square. Test the coils for proper resistance, and then check the points also. As for removing the coils, you don’t remove the laminates from the stator, you pry the coils off of the laminates if needed. This is easier than it sounds. Good luck, and welcome to the club! Keep us posted, I will help as much as I can.
        Steve
        #174661
          I always test all my condensers with a Stevens magneto analyzer, which is similar to the Merc-O-tronic. Almost with out fail, old Phelon condensers will fail a leakage test. My two cents would therefore be to buy some new condensers and have nothing to worry about. Like 20Mercman says, those mags are generally good, though. To test the points, disconnect them from everything and check with an ohm meter on low ohms scale. Resistance should be ZERO. If there is so much as one ohm, the mag won’t work right.
          #174710
          nicholas soper
            Thanks for the feedback guys. I ordered new condensers, but naturally the actual replacement is listed as NLA. I’m order the recommended replacement, but waiting to test the new condensers before I remove the coils.
            In regards to testing the coils…. Since the laminates are riveted to the aluminum plate for the magneto; Am I correct in my understanding that to properly test the resistance of the coils I would have to remove them from the laminates? If they are still attached to the magneto plate the Ohms would be whatever the whole magneto reads as one unit, rather than individually correct?
            I’ll pull the points for a good cleaning and testing to make sure they are working correctly. Thanks again.
            Any insight yet as to how to load photos?
            #174712
              coils must stay on the laminations to be tested. disconnect the coil wires before testing.
              #176564
              nicholas soper
                Well it turns out that the condensers were Ok. The points were just dirty, and after a quick filing and regap they seem to be pretty good. That’s great news since the replacement condensers were not going to fit well without some modifications. I have since replaced the water pump impeller and seals, overhauled the fuel pump and carburetor, and had it running in the barrel. Unfortunately the short fuel line between the fuel pump and carb is cracked and leaking, so I am waiting on a replacement from MarineEngine.
                Also getting some new rubber seals for the water pipe sections. It pumps water out the tell-tale, but just a trickle and I’m hoping that the seals help improve the water flow. I’m assuming that when the engine is running at “shift range” speed, that there should be a pretty decent amount of water flow correct? More that a trickle?
                #176571
                  the tell tail is just that .maybe just clogged a little. try a paper clip to un clog or use compressed air. if the motor is running cool the pump is working. top of block should have a 1/8 pipe plug to check the pumping.. 1 914 310 7086.
                  #176657
                  nicholas soper
                    Thanks for the input dave-bernard. I haven’t had time to test it again yet, but here’s pics of it on the stand in the garage. Hopefully tonight I will get a chance to try and make sure the passages are clear.
                    IMG_5885-copy
                    IMG_5884-copy
                    IMG_5882-copy
                    • This reply was modified 7 years, 5 months ago by CHUCK.
                    #176678
                    JayzonAych
                      That is a really nice one and cool that is has your family heritage attached to it…
                      The cloud white usually didn’t hold up well on those. Meguiar’s cleaner wax will make it look really nice. Wash it with blue Dawn first
                      Did the coils have a yellow epoxy securing them to laminate cores? If so, they have a near 100% failure rate by now and I would be shocked they are still working. Most failed within warranty and have long been replaced with the better ones that did not use the yellow epoxy.
                      I have had 5 of 63’s and still have the nicest one I came across.
                      If you want the motor to run well at trolling and idle you may need to get into crank seals and resealing crankcase with loctite 518. The top crank seal can be done by removing top crank bearing carrier, the bottom takes 2 seals stacked and the requires splitting crankcase. Of course give it a try before you get into all that and see if it runs desirably.
                      I had one motor that mud dabbers made a nest in the idle muffler found under the u shaped plate in the rear of pan and clogged it up. Motor would not idle after all that work I described above until I cleared it. The function of this chamber is to muffle the exhaust at idle and provide back pressure relief at idle and trolling since engine is deep in water.
                      That telltale will always be an issue. Its design allows it to clog easily. As Dave mentions there is a plug on top of engine near exhaust plate on later motors and even later models ran telltale form this port. Unfortunately your 63 likely doesn’t have the plug or boss to tap into. You’d have to get location from a later model and tapping would be risky as metal is thin in that area.
                      • This reply was modified 7 years, 5 months ago by JayzonAych.
                      #176700
                      nicholas soper
                        Thanks JayzonAych. Yes the coils have the yellow epoxy in them. That is precisely why I never attempted to remove them from the base plate and laminations when I was testing them previously. SO Far…. They seem to be working fine. I have the original coils and condensers in the motor now and it runs pretty well in the barrel if it gets some throttle, but really struggles as it drops down toward idle and trolling. I had attributed the rough idle to the leaking fuel line and misadjustment on my part. But that sounds like it may not be the case. So the chamber that provides back pressure relief for idle, is that the outlet port that is molded into the bottom/rear/center of the lower pan? It seems to have exhaust and some water coming out of it at times.
                        I also included a shot of my complicated way of testing the water pump. I had tried to use my cordless drill but the motor’s drive shaft was too large to fit into the chuck. So I hauled the drill press out of the back of the garage( assuming that I would manage to dump water everywhere) and loaded the lower gearbox and water pump into the drill press. It was a difficult way to test, but it worked like a charm.
                        I didn’t get a chance to work on the Mercury tonight as I went for ride on my other perpetual project…. a1971 Honda CL450. Apparently I have a thing for machines that need a lot of TLC.
                        IMG_6166-copy
                        IMG_6171-copy
                        IMG_6172-copy
                        • This reply was modified 7 years, 5 months ago by Mumbles.
