Home › Forum › Ask A Member › New project 1-14 Scott Atwater 501 4 hp needs coil
  • #32110
    fishingnuts
      Impeller is ordered, finally down to the gear box, all looks good, will need the prop shaft seal It has a number on it GK100-J032F not finding that anywhere. Hopefully this will be my last part needed.
      #32111
      fishingnuts
        Hey fellow, never mind about the seal. I found a water pump seal that is the same size, had it in stock. It was an OMC seal.
        Again, thanks to all for the help. Will make a final post when its up and running.
        Ed
        #32155
        fishingnuts
          Impeller is ordered. I started on the gear case. First one I’ve taken apart that is full of grease. Has grease written by the drain plug. So I guess grease goes back in. Any type of grease, or suggestions?
          #32161
            Outboard motor gear grease is no longer made by anybody. Most people use Lubriplate 105 "Motor Assembly Grease", available at NAPA Auto Parts Stores. It comes in a handy squeeze tube. Another popular lube is Corn Head Grease, available from John Deere dealers. Good stuff, but not as handy to get in the gearcase, as it comes in a standard grease gun cartridge.
            #32163
            fishingnuts
              Next question, need a replacement boot for the spark plug, would like to keep the clip on plug wire, instead of changing to the newer style.
              #32175
              david-bartlett
                quote fishingnuts:
                This is what I am using. I get it at Tractor Supply.
                fishingnuts
                  I guess a trip to Tractor Supply. Wish I had one a little closer.
                  Thanks for sharing.
                  Ed
                  #32193
                    Fishing nut,
                    I just bought a Scott / Firestone 10hp impeller from Flying Scott guy. It fits & works very well too!
                    #32198
                    jim-moffatt
                      Spark plug boots are available frm Russ Larson, the Martin SIG leader. He is linked off the aomci site.
