Home › Forum › Ask A Member › New coils no spark 1956 15 hp evinrude
- This topic has 50 replies, 17 voices, and was last updated 2 years, 8 months ago by
JACQUES.
September 26, 2020 at 10:55 pm #217371
Installed new coils, spark plug wires & cleaned points. No spark on either cylinder. ?? Coils primary and secondary were checked.
September 26, 2020 at 11:19 pm #217372Make sure you connected the coil wires to the correct set of points. Set your point gaps at 0.020″ when open.
Hope it helps.
Best, PM T2
September 27, 2020 at 2:27 am #217378may be bad condensers
September 27, 2020 at 8:48 am #217385Make sure your points are CLEAN! If you put in new points clean them also. VERY important!
dale
September 27, 2020 at 9:21 am #217395Did you set the coil air gaps properly? Is the point cam installed right side up, don’t know if it is possible to install it upside down though…
September 28, 2020 at 8:52 am #217457Check everything with an electrical meter as assembled. You can bet you have bad capicators too. Have a Merc o tronic test tool ? I check for resistance in the points assembly, also will show E faults. Most multi meters have a capacitance setting although it doesn’t “load” test the cap. By the way what exactly does a condensor condense? ……Moonshine?? Out dated term for a capacitor.
September 28, 2020 at 11:03 am #217463I had encountered the same thing. The coil needs need to be located in correct position to get the good air gap (it is better with the coil set up ring (ID = 4.468″). I got this number from the web and made the ring. It worked well. Then you need to set up the timing correctly. Forget about 0.020″ gap, just go with timing by the multimeter method and get the spark right away! But just make sure the condenser is good first.
September 28, 2020 at 11:54 am #217471How did you make the ring? I’ve done everything. I think it is probably the air gap since I had to put new coils on the engine.
September 28, 2020 at 12:26 pm #217473I have an aluminum tubing with 6″ OD and 4.0″ ID. I slide it 1.25″ thick and put in the lathe to bore out to 4.468″ ID. and clean up both sides to make it look good. You don’t need 1.25″ thick, It could be 1″ thick. If you don’t have tubing, just use 6″ x 6″ x 1″ or 3/4″ plate and bore out the ID. It does not look good but square plate with this ID could serve the purpose.
September 28, 2020 at 12:30 pm #217474I took my digital caliper and set it to your dimension and checked across the coils. I had a reading of 4.464. This is from the original installation of the new coils. Do you think I can set the air gap this way bearing in mind to watch the circumference points of the coils not touching the flywheel.
