Home › Forum › Ask A Member › New Coils For An Old ELTO
- This topic has 61 replies, 17 voices, and was last updated 3 years, 5 months ago by
Monte NZ.
May 3, 2023 at 5:16 am #275830
Thanks Wayne…….you made my day! I know it will be tight, but I will give it a go and hopefully report back with positive results.
Thanks again
Monte NZ
May 17, 2023 at 7:12 pm #276313In making up this new coil setup using two standard OMC coils, I’m wondering how to connect the wiring of the two coils.
Do I connect then in parallel?
Any help and even a diagram, if possible, would be much appreciated.
Monte NZ
May 18, 2023 at 10:28 am #276323
I’m not very good at understanding diagrams
so I’m not very good at making them. Hope
you can make some sense out of this.
Tubs.
May 19, 2023 at 12:55 am #276333Thanks very much Tubs for your reply………your pictures and sketch are most helpful.
One question I have though, is that your diagram shows the two coils mounted on the one laminated iron core, (both facing the same way like you instructed) whereas I’m hoping to use, two standard OMC coils with the laminations that they all come with.
What I’m wondering is, do the laminations of the two coils, need to be connected in some way, to form the same setup (one piece iron core), as your drawing shows?
Thanks again for your help!
Monte NZ
May 19, 2023 at 9:30 am #276339
I don’t know the answer.
My guess would be that they need to be connected.
May 20, 2023 at 6:29 am #276357Thanks Tubs for your reply. I think I will join them up and see what happens
when I get a chance in the next day or two….. will let you know the results.
Thanks again
Monte NZ
May 26, 2023 at 7:40 am #276466Hi Tubs and Wayne. I got it all together tonight and it works! It was a snug fit getting it all into the tube and as the condenser is already mounted inside the timer on my motor there was no need to fit one in or on the coil case. All I have to do now is paint the unit and fit the spark plug connectors to the HT leads.
I ended up bolting the two coil laminations together with 1/8 inch nuts bolts and spring washers which made the unit rigid and easy to handle. I will try and post some photos in the next day or so.
Thanks very much once again for your help.
Monte NZ
May 27, 2023 at 1:18 am #276478Hi all. Here is the link to photos of the coil setup.
https://photos.app.goo.gl/<wbr />AjoesBoowvKrUjeY7
Monte NZ
May 27, 2023 at 8:49 am #276481Monte, that’s pretty ingenious how you sandwiched those two
coils together like that. What did you use to house them in?Prepare to be boarded!
May 27, 2023 at 9:25 am #276486
Interesting that the coils seem to
work facing back to back.
