Home › Forum › Ask A Member › neutral/drive on 1953 5hp gale help
  • #284841
    Hiawatha
      clutch lever
      took apart lower unit to check impeller, somehow can’t figure out how the clutch lever contacts driver to put in or take out of drive, wonder if i broke off a tab? Help!!!
      what i’m having a hard time understanding is when you pull the lever up the throw into neutral the clutch lever in the lower unit moves down towards the prop. i’ve been looking at this so long maybe i need to step back from it lol
      thanks dave
      #284843
      Hiawatha
        figured it out!!! found some aomci archives that nailed it!!! what a site, thank you!!!!
