Home › Forum › Ask A Member › Neptune model 500 carb/ Tillotson HS93A
  • #298237
    Edwin Howard
      US Junior Member
      I have a frankensteined Neptune Wc1 that has the carb, reeds, and throttle/mag plate advance lever from a Model 500. I have had trouble with it idling down, it runs fine at high speeds but coughs and dies at slow speeds. I have checked and the low speed passageway is clear. I believe that the low speed needle is damaged, and I wondered if anyone out there with a model 500 can find a picture of what a good low speed needle looks like. I can provide any pictures of the motor if necessary.
      #298246
      JOSEPH BRINCAT
        Correct me if wrong , but Tillotson carb low speed is an air bleed , so closing the needle richens , opening leans. Just the opposite from what might expect And might explain why you are having trouble.
        #298248
        CHUCK
          Joe;  is there a way to tell by looking at a carburetor whether it is an air bleed design?
          #298251
          JOSEPH BRINCAT
            Again I may need correction here , but the air bleed carbs usually have the low speed needle up high and to the side of the carb rather than the more common front location along side of the high speed needle
            Post a picture if you can
            #298252
            A. Hoskins
              A damaged needle, examined with a magnifying glass, will show a groove or irregularities in the tapered section. If you see such, chuck the needle up in your electric drill, spin it and polish it with some 600 grit wet-or-dry. When the engines “coughs” and dies, pull the plug. Is it wet or dry ? An overly rich mixture (wet plug) usually won’t cough to a stop but it will choke down and stop without spitting back through the carb if that is what you mean. Good luck.
              Certified JB weld
              #298273
              Edwin Howard
                US Junior Member
                1000007065
                1000007066
                1000007067
                Here’s the carb, it’s not the typical outboard carb. I believe that it is related to some sort of chainsaw carb. The low speed needle is marked with an L in the casting. There is no packing, so a bit of gas ends up outside the needle on top of the carb and the spring keeps it in place. Once coughing and shutting off, the plug appears mostly dry. I also attached a picture of the low speed needle. I am not sure what it is supposed to look like, but I assume that it should taper down like most needles.
                #298277
                Edwin Howard
                  US Junior Member
                  1000007065-1
                  1000007066-1
                  1000007067-1
                  #298281
                  Edwin Howard
                    US Junior Member
                    1000007065-2
                    1000007066-2
                    1000007067-2
                    #298283
                    George Emmanuel
                      Folks, Edwin is my grandson…the carb on his motor is not the Tillotson but rather a pumper/diaphragm style, and I can’t remember the name. It think it is something like Walbro.
                      George
                      #298287
                      Edwin Howard
                        US Junior Member
                        Here are 2 more pictures of the carb
                        1000007070
                        1000007069
