Home › Forum › Ask A Member › Neptune A2 Water Pump
  • #4776
    collectorinspector
      Hi all
      It needs investigation as when running not a lot of water flow etc.
      Doug P sent me a kit including a new cam etc.
      My Q4U is can someone post a diagram of the lower unit so I have an idea what is inside please?
      Before I put it back together I would like to know how far to pull apart to check with compressed air any tubing back to the power head.
      Gearbox should be serviced while pulled so an idea how it all relates etc
      Cheers
      BnC
      #40373
      cajuncook1
        collectorinspector
          NUP!
          BnC
          #40458
            Maybe this site will have something to help;
            http://muncie-neptuneoutboard.com/
            Good Luck with your motor.
            Steve A W
            #40624
            collectorinspector
              NUP!
              Motor does not appear yet.
              BnC
              #40736
              collectorinspector
                Ok
                A couple of pics…..
                I can pull it apart as seems outwardly straight forward. However, not having worked on anything but the wee ones…….best to ask if there are traps or pitfalls to consider.
                BnC
