Home › Forum › Ask A Member › Neptune 2a38 muffler?
  • #2712
    martin20
      Hi, Just acquired a Neptune model 2a38 and was wanting to know if it could possibly have a factory muffler on it, if there is such a thing..This motor has one on it, and whoever put it on either done a fantastic job or it came that way. Never seen one on an older outboard before so I am curious. Looks like a lawn mower muffler, but has the same patina to it,as the motor. It is perfectly centered on the exhaust tube, just looks to good to be a cobble job.Thanks for any info
      #25196
      RICHARD A. WHITE
        Pictures?????? I restored one many years ago, should be a long brass tube that curves AND flares just above the cavitation plate. Anything else is wrong.
        This picture is of a 1937 Neptune 2 hp I restored for an old friend, he has since passed and his son keeps it in the living room…
        classicomctools@gmail.com
        #25205
        martin20
          Richard, trying to figure out how to post a picture. Exhaust tube is the same as your motor,just has a muffler sticking out of the tube.Probably not supposed to be there,but just checkin
          #25218
          RICHARD A. WHITE
            Click the little pencil near the top right of your post, then after that you will find near the bottom left a tab that says "attachments" follow the instructions.
            Once you choose a file from your computer and click add file, you should see an option to "place inline".
            Place you cursor where you want the picture to actually show up in your text, I usually place mine at the end, then click the "place inline" button, then post it.
            Good luck
            Richard
            #25379
            martin20
              Not finding the "attachments" tab Richard.
              #25397
              RICHARD A. WHITE
                When replying to this message, click the "Full Editor & Preview" button..
                Look below the box you are typing in you will see an "options" tab as next to it you will see the "attachments" tab
                See photo below:
                #25404
                  • This reply was modified 7 years, 11 months ago by Tubs.
                  #55971
                  keplerfan
                    Anybody know how to separate the brass shaft tube from the water pump – right on top of the lower unit? There are three screws at the base of the shaft tube. I pulled those but still stuck. I don’t want to break it with a hammer so I need a different method… Heat? ..I dunno…
                    #55972
                    keplerfan
                      I mean on this 2a38 motor……
