Home › Forum › Ask A Member › Need the diagrams for a 4378 Zephyr
  • #3050
    wyo307
      Hello everyone,
      I am in need of the diagrams for a Evinrude Zephyr model 4378 circa 1945. I contacted mumbles but all he had was the ones for the 4404 so the carb was a little different. Mine doesn’t have a primer on it.
      Also when i was disassembling the carb I managed to brake the small tube that is labelled as the "air bleed" (Part #275251) in the diagram I do have. Is the tube all that important or can I just run it with the plug with just the hole in it instead of the tube?
      Thank you all in advance,
      Ryan
      #27711
      ray-schaber
        I think you need that tube to supply idle air when the carburetor is set to slow.
        You can probably get a new piece of tubing at a hobby shop. Take the old piece with you to the store.
        Ray
        #27713
        Monte NZ
          Hi Wyo307 (Ryan)
          I have a copy of the Operating Instructions (includes parts section with diagrams) for the Evinrude Zephyr Models 4378-4379,
          which I would be very happy to scan and forward to you. If it is OK with you, I would need your email address.
          Time is a bit of a problem at present with the Christmas Season keeping me well occupied, but if can give me a few days I would be delighted to help you out.
          Kind regards
          MonteNZ
          #27723
          wyo307
            MonteNZ I sent you a pm with my email address.
