Home › Forum › Ask A Member › Need some Merc help
  • #2276
    wiscoboater
      Hi guys,
      I need some help here. I’m not a Merc guy, and I’m quite unfamiliar with them. I picked up a 1967 Merc 200 that was a tiller motor. Thanks to 20mercman he steered me to a NOS conversion kit for it on Ebay and I picked that up. Now my dilemma is the controller. I see at least 4 or 5 different styles/types of Merc controllers searching on Ebay. What model of Merc control should I be looking at to hook this all up? I know the 200 uses a unique cam inside the control box, but what is the proper box?
      Another option I’m throwing around in my head is going Frankenstein and using an old J/E two lever controller since I only need throttle and shift (no electric start or choke on this motor) Can the Merc cables be used with the J/E controller?
      Confused in Wisconsin
      #22127
        I don’t know of any simple way to use OMC controls on a Merc. While anything is possible, it would not be simple.
        If someone doesn’t have a simpler way to answer your question, I just checked and I do have enough literature to be able to give you a correct control box part number and numbers for internal parts of that control box. However, I would need to know what your serial number for the engine is and also, if you have electric start on the engine. (Not even sure that was available in ’67; but I go by serial number, not year.)
        #22139
        wiscoboater
          Thank you Bill,
          The serial# is 2151677. The motor has no electric start, and I do not want to add one. This motor is for a 10′ wooden Gentleman’s racer styled after the like boats from the 50’s. It’s all about going fast…no frills.
          #22140
            Call me 1 914 310 7086. Dave.
            #22146
              Looks like Dave must have a simpler way to answer your question; but if you still need any info, just let me know.
              #22150
                Wannabe let me know what you find. I have a 1975 Mercury 200 I want to add as a kicker to my fishing rig and would like to run controls for it as well so I don’t have to lean off the transom to shift it and adjust throttle!
                #22155
                  Chris yours is new enough and should take the square box single lever normal shift. if memory is correct.
