Home › Forum › Ask A Member › Need more main jet seals
  • #2244
    Hugh Long
      I seam to have lost the part number for the fat o ring that works to replace the main jet seal on the smaller Johnson/Evinrudes. Anyone have the info? I thought I bought enough last but, more and more and more… outboards
      AKA Outlaw Outboards in Fallon, Nv
      Now in Twain Harte, Ca
      #21910
        Hugh,
        I have the book in front of me. Tell me an example to give you a part number. Here is one seal #301999 Does that look right?
        #21919
        Hugh Long
          The factory part is 0344037 1963 Johnson 3 hp and such. $5 ea. It is flat rubber with a hole in it like if you cut 1/4 inch off a fuel line. I have been using a fat O ring that can handle the fuel. Someone in the club listed the o ring part number 4 or 5 years ago. I bought 50 of them, but ran out. super cheap.
          #21924
          cajuncook1
            Application = Replacement of OMC carburetor Boss/High Speed gasket
            Type of O-Ring = Buna-N 201
            OD (outer diameter) = 7/16" or 0.449"
            ID (inner diameter) = 3/16" or 0.171"
            thickness = 1/8" or 0.139"
            Web link if applicable = http://www.mcmaster.com
            McMaster information
            Oil-Resistant Buna-N
            I believe this is the correct part number
            9452K337
            bag of 100 for $2.77
            #21925
              201B
              #21927
              Hugh Long
                Make that 400. I will send out packs of 25 or so if anyone needs some. Just email me your address.This time I will buy 100 ?? Or hang on to the part number. Thanks 😉
                #21934
                Casey Lynn
                  For off the wall applications or hard to find Orings, this store will normally have what you need and shipping is sometimes better.
                  http://www.theoringstore.com/
                  #21939
                  cajuncook1
                    quote Pappy:
                    Pappy, thanks for that link!! 😎
                    #21954
                    Hugh Long
                      Same here Pappy. I checked it out and looks to be another good source, so I bookmarked it.
