Home › Forum › Ask A Member › need info Old merc
  • #260083
      Dave?   Anyone ?     any info on this one ?  easy to fix or nightmare ??
      • This topic was modified 4 years, 5 months ago by JACQUES.
      #260088
        They are a good motor . fuel pump is a hard job. you have the shift knobs that is a +++++++++++++
        #260091
          Is that the Silent Six? Those are nice running motors if in good shape,
          but harder to work on than an OMC.
            i’ll low ball it at 65$    wants  $350    for 65$ I can endure the challenge
            and it is a 6hp.   compact little guy 🙂   what year is it  and mdl # ???
            • This reply was modified 4 years, 5 months ago by JACQUES.
            #260105
              Mark 6 mid 50’s
              #260121
                thanks.. no bites on the low ball yet ….
                found this on utube…. looks like nice motors
                (1569) 1957 Mercury Mark 6 Super Silent Six – YouTube
                (1569) 1957 Mercury Super Silent Six Mark 6 part 3 – YouTube
                #260127
                  Very nice running motors and fast for a 6, on a light boat. Also one of the most frustrating-to-work-on engines that you will EVER find. I personally think they are harder to deal with than the automatic transmission Mercs.
                  BIG, BIG failure point on those, just like Mark 5s…..Gear case is very light duty and prone to water intrusion. What happens very often, is that backwards pressure is built up in the gear case, from bad bearings, ice, hard use, etc., and will push the prop shaft bearing carrier out slightly to the rear, breaking off about an eighth-inch ring of the gear case’s aluminum. Since it’s small, if you’re not looking for the problem, you won’t even notice that it’s missing; and it makes the gear case toast.
                  On the plus side, that one seems to have two good shift knobs. They are usually broken. Minus side, the front plastic emblem is broken, no surprise there. If it turns over with bounce and the gear case is not broken, I’d say it was worth as much as a buck and a half, but nowhere close to $350.
                  • This reply was modified 4 years, 5 months ago by billw.
                  #260133
                    Billw. thanks  for the heads-up on a possible nightmare…. the  seller declined my generous offer ….above $1.50   🙂
                    I was on the dark side for  several years witn my first 9.8 late 60s  and a 20hp which  punched a hole inthe crankcase ,  a merc 500 and a Merc 45 hp Classic 50 (both fantastic motors)
                    my 75 ETEC runs great ..since 2005  as does my 9622a since 1966 !!     so I,ll stick with  OMC BRP stuff  🙂
