Home › Forum › Ask A Member › Need coils for 7.5 HP elgin
  • #304453
    Carl Rousseau
      Where can I get a couple of X7500 coils for a 1954 7.5 HP Elgin?  My specific model is 571.58772.  I may also need a pair of X7388FT lead wires, X7046 points, and an X9182 condenser.
      #304468
      CHUCK
        Carl;  would it be possible for you to post a picture of your magneto?
        If your coil laminates are about 7/16  high  and just a bit more than 7/16 wide….you are in luck because you can retrofit a pair of the common OMC coils.  Although some laminates are quite a bit heftier than that….so it would help with a picture.
        Points can most often be cleaned and polished and re-used.  A variety Condensers can be made to work,  spark plug wires can be purchased at a lawn mower shop or auto supply store.  Copper core wire.
        Member Tubs has a great video showing the OMC conversion.  If he sees this I bet he will post a link to it.
        #304479
          I believe you have this Wico magneto. If that is the case, these pictures are of the modification Seakaye has described above.  Here is a video link of the modification on a 7.5 hp. Mercury Phelon magneto .  https://youtu.be/OxPHe8EPe1Q?si=yu99T33CLZ52zeC5
          Wico-twin
          #304593
          Carl Rousseau
            thank you tubs and seakaye12!  this should help a lot.  As for a photo, I tried but was blocked.  Sent email to forums@aomci.org.
            #304594
            Carl Rousseau
              RICHARD A. WHITE
                Your post was blocked?
                classicomctools@gmail.com
                #306997
                Carl Rousseau
                  photo upload was blockedold_elgin_coils
                  *.jpg was blocked.  tried saving as *.pdf and that upload was blocked, too.
                  #306999
                  Carl Rousseau
                    or maybe not?
                    #307004
                    Carl Rousseau
                      ok.  watched the youtube video.  the Phelon 398-173 – Coil is not available.  Anyone know of any other similar p/n’s that are still able to be purchased?
                      #307006
                      Carl Rousseau
                        18-5178 Sierra is listed as an alternate but does not look like it would fit my Elgin, and it also currently out of stock.  Ditto for 72120 GLM.
