Home › Forum › Ask A Member › Need an OMC carb needle clip
  • #5399
      I just realized I’m going to need to pull the carb on a 1959 Electric Start Fastwin project I’ve been (slowly) working on for two years (I’ve just finished wiring up a new harness for it), to hook up the choke solenoid. When I got it, I opened up the carb, and found a new rubber tipped needle, but without the retaining clip (it also had a carbon "suppressor" spark plug wire), and I remember I was lazy and just bent a paper staple in the right shape. I probably also used model airplane dope on the old float, which there has since been reported to fail… So maybe I should just get a new BRP kit with a plastic float?
      #45017
      amuller
        You can probably get a clip from a mower shop or any sort of small engine place. They are all pretty similar.
        #45019
        David Stanton
          A similar clip was used on several automotive carbs too. I’ve seen motors with the clip left off that work fine too.
          amuller
            quote outbdnut2:
            Yes, most of the time it doesn’t matter. The issue is that occasionally a rubber-tipped needle will stick in it’s seat and "no gas." Metal tipped needles don’t have the clip as the are far less likely to stick (but a lot more likely to leak). Of course, there are setups with metal needles and rubber seats.
