Home › Forum › Ask A Member › Need 1956 Johnson CD-13, 5.5 Hp Lower Unit Seals
  • #328889
    LARRY CATON
      I looked in the Classified section and didn’t see any members selling seals or kits.  I also looked online and wasn’t having much luck.  I know we’re not supposed to sell items in the Ask A Member section, but I need help finding parts.
      Can somebody point me in the right direction to find these seals?
      300599 Drive Shaft Seal below water pump wear plate
      303345 Seal –aft prop shaft
      303360 O-Ring, prop shaft
      303328 Seal, spaghetti
      I have the seal for the shift rod, and maybe the spaghetti seal.  IDK if different gear cases use different diameter spaghetti?
      1956 Johnson 15 Hp, FD-10
      1957 Johnson 5.5 Hp, CD-14
      1958 Johnson 5.5 Hp, CD-15
      #328891
        check with the folks at vintage outboard for kits I used .103 spaghetti last time I did mine make  100% certain the clutch is not stretched before closing up !!
        call them up for exact kit#
        Johnson Evinrude outboard impellers, seals, lower unit kits, water pump kits, gaskets – VintageOutboard.com
        #328908
          If all else fails, you can try sourcing seals via “size” using
          the lookup link here….
          CR Seal Finder
          Also, McMaster Carr sells the spaghetti seal in bulk.
          Search on site for the size, I know it’s been brought up before.
          #328909
            I’m pretty sure they are all still available, did you look on marineengine.com?
            #328922
              Seal kit for that motor is Sierra 18-2679.   Includes all the parts and pieces you noted.
              1982 Evinrude 25hp
              #328955
              LARRY CATON
                Hi Jacques,
                When you say to make sure that the clutch isn’t stretched, are you talking about what the parts book calls the “pinion shaft and shock absorber assembly”?  Does that lower shaft & assembly just pull out by grabbing the pinion gear?
                Since I haven’t done this before, IDK what normal vs stretched looks like, or what the remedy is if it’s stretched.
                Do you know if there’s an existing post about it, or if it’s in “the Red Book”?
                Thanks so much!
                #328957
                  the clutch (SHOCK ABSORBER)   spring will sometimes break  causing it to strech enough to cause rub marks on the underside of the water pump  and as was my case….. caused all sorts of headhaches  cloosing up the  LU .  it repeatedly failed pressure testing until i realized the problem.
                  I had  my friend  tack weld the thing at 6″11/16  on 3 spots around and  made certain the welds did not protude …we simply polish them up with a grindrer.
                  The  cluch is removed by removing the water pump layers and simply pulled out.    With theshock absorb capabilities gone  I used a 3/16 brass rod to cut me some  brass drive pins.
                  5.5 OMC Shock Absorber Removal
                  it is pictured in the shock-2
                  shock-2
                  red book in the CD section of the LU pages
                  #329063
                  LARRY CATON
                    Thanks so much for the video link!
                    I read the section in the Red book, but was surprised that it didn’t say anything other than it doesn’t need service unless it’s broken.  I’ve already made a bunch of brass shear pins, and have a variety of welders to make the repair if necessary.  I was surprised when I replaced seals on my FD-10 that the factory seals were still in place. I could see over spray of factory paint.  Now I took apart this CD-13, and found the same thing!
                    All of the bushings, gears, etc. look good on both the CD-13 and CD-15.  I need to put the clutch dogs side by side to see which is in better shape, but at first glance, there’s minimal wear.
                    I appreciate everyone helping me learn and showing me where to find parts.
