Home › Forum › Ask A Member › Narrow nozzle for grease guns ?
  • #5846
      do they make narrow body (slim) grease gun nozzles for grease zerts
      on the 9622a 9.5hp the shifter handle is e/w a grease zert yet it is so close to the lower housing sidewall that a regular grease gun cannot clamp solidly on the zert to inject grease
      those zerts seem pressure fitted which I found out by looking closer.
      Silly me purchased 45 degree threaded zerts 1/4 by 28 which of course do not thread in and can’t be installed anyway because….. it is to close to the side wall ๐Ÿ™„
      Joining AOMCI has priviledges ๐Ÿ™‚
      #48660
        Yes, go to an auto supply house. They will have one that slides on from the side.
        #48672
        david-bartlett
          Crosbyman,
          Yes there are slim grease gun tips for tight quarters. Usually they cost a little more, but worth it.
          #48678
            If you can find one of these push type of grease guns, it will fit all of the fittings on any outboard motor. I think they still make them.
              There are grease guns with a pointy end for chainsaw nose rollers
              #48725
              amuller
                I think the hold-it-on type of grease gun fitting is probably indicated. In my experience anyway, the clamp-on type of coupling often clamps too hard and pulls out the pressed in type of zerk fitting. You can get a kit of various grease fittings–needle, pointy rubber tip, various angles, etc.
                #48741
                  mumbles….. I have one like that….somewhere….It was my first grease gun years ago… now I have to find it ๐Ÿ˜†
