Home › Forum › Ask A Member › My demonstration of ignorance this week
  • #1621
    archangel
      I am replacing all of the usual ignition components on my TN-27. I had been careful about the whole business as I did it to be sure I didn’t lose any parts, BUT . . . at one point, when the disassembly was nearly complete, I turned the armature plate over and two lock washers fell on the table. They were obviously missed because the plate was pretty gummy and greasy despite the care I thought I was taking. Trouble is, I can’t figure out where they go now that I am reassembling. I suspect, after a lot of searching the parts diagrams, that they are part no. 3-28. Are there washers on on both sides of the timing lever on the screws that fasten it to the armature plate? Any guidance would be appreciated. 😳
      #17103
      beerman57
        Is the mag plate held down with the 3rd bolt that holds the coils AND the 2 other small bolts? Are the lock washers pretty small? They might be for "2 other small bolts".
        #17104
          That’s what I was thinkin
          #17112
          archangel
            Those machine screws at the centre of the plate have flat washers on them. Did they have lock washers also?
            #17124
            david-bartlett
              Archangel,
              If it makes you feel any better, today I spent the better part of 2 hours chasing a no spark on one plug issue on a 1968 Lightwin. First I swapped plugs, then cleaned the points, then swapped a condenser, then the coil. No Joy!
              Then it dawned on me that I was on the wrong side of the Mag plate from where I should have been!!!! Cleaned the other set of points and running on 2 cylinders again.
              Humility has it’s place.
              #17128
              archangel
                Thanks, Dave. It isn’t interesting if it isn’t a challenge, right? You and I probably just needed to spice up the simple stuff so we subconsciously made the easy stuff harder. 😉
