Home › Forum › Ask A Member › motor stand
  • #202544
    piddler
      Test stand ideas
      #202658
        depends how fancy you want it… I just built one from a scrap piece of 2×6 couple of 2×4 2×3 and 4 casters from Wal Mart total cost about 35$ CDN see pict
        on mine I preferred to put the angled members at the other end of the base frame where the gas tank sits to center to motor on the stand to keep the weight centered
        lots of plans on internet that picture in not my own stand……. it is an example from pictures on the internet
        https://www.bing.com/videos/search?q=outboard+motor+stands&&view=detail&mid=94C3F27892D38DEE115794C3F27892D38DEE1157&&FORM=VDRVRV
        next video important section starts at 1:30
        https://www.bing.com/videos/search?q=outboard+motor+stands&&view=detail&mid=154AA574DBAE01BFCAD2154AA574DBAE01BFCAD2&&FORM=VDRVRV
        • This reply was modified 6 years, 6 months ago by JACQUES.
        #202666
          #202670
            I have a couple of these home-built stands I use for work/display stands and barrel testing.
            IMG_6564
            IMG_6472
            1982 Evinrude 25hp
            #202838
            need2fish
              O, that is a gorgeous RD… mine are still in baskets.
              #202863
              kerry
                Years ago I built one similar to Tubs’, but using a blue plastic 55 gallon barrel I cut down to size. Later I added a shelf to hold a gas tank, after discovering some fuel pumps (Mikuni in my case) would not “lift” fuel from ground level. From the shelf to the carb of a 1958 Fleetwin was 18″, never had issues afterward.
