Home › Forum › Ask A Member › More bad OMC coils made in China
  • #273275
      I have a  30$  injector tester box  on order from Amazon … basically a  programmable pulse  generator to  pulse and clean injectors.
      when I receive it i’ll use it to pulse  ignition coils to see what sparks comes out the secondary.     who knows it may serve as a basic  coil tester….because I do noyt have a fancy
      Merc O tronic
      I figured maybe if it can energize an injector it may  help to test coils .  maybe not  at max voltages  but a dead coil is a dead coil…… all things considered.
      will let you know ….when it comes in ….from China .. Sorry…!
      #273370
        I have had some of those coils work okay and also have had two that have failed after about ten minutes of run time.
