Home › Forum › Ask A Member › Montgomery Ward Sea King 8.5
  • #242454
    JdgMbi1
      So, I got this for a Fathers Day gift, and other than knowing the name (growing up on the Puget Sound in the Seattle area), I know next to nothing about this engine. What makes things worse, I can’t seem to find anything that represents the model number, or such. I can find a bunch of numbers (which I think are part numbers), but nothing that I can correlate back to a model. the motor appears to be in good shape and someone has already started a re-store, and I would like to finish it, but obviously can’t do that, if I don’t know where to start. I am attaching photos in hopes of someone being able to steer me in the correct direction.
      Thanks in advance for any help you all can lend here.
      If these photos are not helpful, please let me know which ones you need.
      20210620_120200
      20210630_184135
      20210630_184055
      20210628_170435
      • This topic was modified 5 years, 4 months ago by Mumbles.
      #242472
        Click on link below—
        https://www.aomci.org/forums/topic/is-there-a-vintage-sea-king-expert-in-the-house/
        • This reply was modified 5 years, 4 months ago by Tubs.
        #242518
        JdgMbi1
          Thanks. I saw that, but I can’t even seem to find the model number anywhere on the thing-Just part numbers (I assume, because they are all different).
          Is there a “Typical” place that the model number would be on one of these things?
          Thanks
          #242551
            I suspect the tag has fallen off or been removed.
            The tag on my Fleetwin was here
            #242557
              This could be your motor with the front cover missing.
              Click on the link below.
              https://www.aomci.org/forums/topic/sea-king-model-492/
              #242611
              JdgMbi1
                Thank you Boat House. There are definitely similarities, as well as differences. Mine doesn’t look like there are the screws available to attach a cover to it?
                Also, the only 400 series numbers I can find are attached. They are on the cylinder heads and the shaft sleeve.
                It seems that no matter what I want to restore, it just can’t be mainstream and parts easily accessible -Lol. I would really like to find a manual, or something to go off of the parts that I am missing.
                Thanks for the help, and any help you can continue to give.
                #242648
                HARRY D. NICHOLSON
                  I think you will find the model number and serial number combination stamped into the lowest edge of the crankcase below the starboard cylinder. Use a flashlight. The number is not cast onto the metal , it is stamped into the metal. My version of your motor is the same except it has a poppet valve carb which makes mine a 8 HP. Yours is 8 1/2 HP with the fancy carb. Mine is a 1933 model 417 with the same crankcase (electric start) as yours and same spring dampened steering handle mount etc. Your tank is a keeper with those nice original decals. Are any decals visible on the ends of the tank??
                  #242649
                  JdgMbi1
                    Thank you, I will take a look tonight. I have noticed that all the part numbers (I have found) are stamped directly into the metal as well. I have all three decals on the take in about the same condition as the rear-Legiable if you squint. I am glad they are keepers because I bet it would be a bugger to fun some repos
                    #242837
                    JdgMbi1
                      So I found the model number and it is in fact a 492. My question is, does the 0051 indicate the exact year. The 492 spaned multiple years?
                      Thank you for the location help, and any other tidbits you can throw my way.
                      #242846
                        The 0051 is likely the serial number of your particular motor.
                        1982 Evinrude 25hp
